Adding a Filled, Closed Polyline to the Library Browser
Reference Number: KB-00037
I would like to be able to add a closed polyline to which I have applied a fill style to my Library Browser to use in future plans. How can I accomplish this task?
Closed polylines can be added to the library browser by first turning it into a CAD block.
To add a closed filled polyline to the Library Browser
  1. Using the Select Objects  tool, click and drag a marquee around the entire enclosed polyline that you have applied a fill style to.
  2. Once you have marquee selected the object, click on the Make CAD Block  edit button.
  3. After the closed polyline has been selected and converted into a CAD Block, click on the Add to Library  edit button to add it to the Library Browser.
  4. If you find in the future that you need to make modifications to this closed polyline after you have placed it from the Library Browser, simply place it in the plan, select it and click on the Explode CAD Block  edit tool to allow for editing.
