Troubleshooting Floor and Ceiling Framing
Reference Number: KB-00400
Chief Architect Premier
When I build framing for my model, the entire structure frames quite nicely. However, despite my best efforts, the floor and ceiling will not frame. Why won't the framing generate in these two areas?
Framing for the floor and ceiling will not generate, even if there is sufficient platform thickness for each, if certain attributes within the Room Specification dialog box are checked. See the procedure below to ensure that these attributes within the Room Specification dialog box are not conflicting with the framing of your model.
To ensure that framing generates properly in your floor and ceiling platforms
  1. First, open the Chief Architect plan in which you are experiencing difficulty producing floor and ceiling framing.
  2. Click the Select Objects  tool, then click in a room in which floor and/or ceiling framing is not generating correctly.
  3. With the room selected, click the Open Object  edit button to open the Room Specification dialog.
  4. On the Structure panel of the Room Specification dialog, make sure that the check boxes for Ceiling Over This Room and Roof Over This Room are checked.
  5. Next, with the Structure panel still active, next to Ceiling Structure, click on the Edit button to display the Ceiling Structure Definition dialog.
    Verify that a Framing material is set, and if not, click on the Select Material button to browse the Library for an appropriate framing material, then click OK.
  6. Repeat this process for the Floor Structure as well, and then click OK to apply the changes to the Room Specification dialog.
  7. Now that you have verified that a Roof and Ceiling are set to be built, and the Floor and Ceiling Structure in the room that wasn't generating framing now have framing materials specified, select Build> Framing> Build Framing  from the menu.
  8. In the Build Framing dialog, check the Build boxes for each type of framing that did not generate correctly before, then click OK to rebuild the selected framing types.
    You can also select the check box for Automatic Floor/Ceiling Framing, Automatic Wall Framing, etc so that these will be regenerated automatically and will not require you to go in to the Build Framing dialog each time you need to have the framing update.
