Deleting Roof Framing
Reference Number: KB-00600
Chief Architect Premier
I deleted the roof in my plan but still see the roof framing. Why is it still there and how do I delete the roof framing as well?
In order to build roof framing in Chief Architect, it's necessary to first build a roof. However, once the framing is created it is independent of the roof planes, allowing you to delete either one without affecting the other.
To delete a roof and roof framing
  1. Select Edit> Delete Objects  from the menu.
  2. In the Delete Objects dialog:
    • Click the radio button beside All Floors.
    • Under the Objects category, check the boxes beside Roof Planes and Roof Baseline Polylines.
    • Under the Framing category, check the boxes beside Roof Trusses and Roof Framing.
  3. Click the Delete button to delete the selected objects and return to the plan.
