Controlling the Display of the Cross Hair
Reference Number: KB-00610
When drawing in Chief Architect, I am used to my mouse pointer being a precision cross hair. It is instead displaying as a regular pointer or a text cursor.
What do I need to do to get the cross hairs back?
The cross hairs are controlled by program preferences for all plans.
To control the display of the Cross Hairs
  1. First, launch Chief Architect and choose the New Plan option; or you can start a new plan by going to File> New Plan .
  2. Select Edit> Preferences .
    Note: On a Mac, instead click on the Chief Architect menu in the top left corner and choose Preferences.
  3. In the Preferences dialog, select the Edit panel.
    • Check Enable in Plan and Cross Section/Elevation Views to use a cross hair cursor in floor plan, cross section, and elevation views. This option is checked by default.
    • Check Enable in Perspective Views to use a cross hair cursor in perspective camera views and overviews.
    • When Synchronize with Cursor is checked, the mouse pointer and cross hairs always move together on screen. If you feel that they do not keep up with your mouse movements, try unchecking this option.
    • Click the color bar to open the Color Chooser dialog and specify the color of the cross hairs.
    • Cross hair size is specified as a percentage of the width of the view window. Specify the Size (%) of Window Width as 100% to extend the cross hairs across the entire screen.
    • Set the Aperture Size, measured in pixels. The aperture is the space where the cross hairs meet. A value of 0 makes the cross hairs meet at a point. Larger numbers leave a gap in the center.
  4. Once you have made any desired changes to the display of the Cross Hair, click OK to apply and close the Preferences dialog.
