Deleting an Entire Floor
Reference Number: KB-00616
I need to delete an unwanted floor in Chief Architect. How do I accomplish this?
After creating a plan, you may want to rebuild a floor or foundation. In order to do so, the existing floor or foundation must be deleted first.
To delete a floor from a plan
  1. Open a plan or start a new plan from scratch by selecting File> New Plan . For the purposes of this article, your plan should have a first floor, second floor and a foundation.
  2. To delete the second floor, you must be on the second floor. Click the Up One Floor button on the toolbar. Once you are on floor two, the Change Floor/Reference button displays the number 2.
  3. From the menu, select Build> Floor> Delete Current Floor to delete Floor 2 and all its contents.
To delete a foundation from a plan
  1. Open a plan or start a new plan from scratch that has a first floor and a foundation
  2. From the menu, select Build> Floor> Delete Foundation .
