I have created a number of custom backdrop images. I have copied the images from my digital camera to my desktop, and now I would like to make them usable in Chief Architect. How do I add them to the program?
Backdrops are images that display behind the model in 3D views, and new backdrops can be created using a variety of graphic file formats. In this article, we will cover the following topics:
Certain rendering techniques, such as Vector View and Glass House, are not setup to display backdrops by default. To adjust this setting, navigate into Edit> Default Settings, expand 3D View Defaults, select Rendering Techniques, then click Edit. In the Rendering Technique Defaults dialog, select the rendering technique in which the specified backdrop is not displaying in, check the Use Backdrop... box, then click OK.
