Creating a Custom Toolbar
Reference Number: KB-00770
I would like to create my own toolbar and control the buttons that display on it.  How can I do this?
You can create custom toolbars with whatever toolbar buttons you need and then dock the toolbar to the top, bottom or side of the Chief Architect window, or let it float undocked in the drawing area.
To create a custom toolbar
  1. Select Tools> Toolbars and Hotkeys> Customize Toolbars  from the menu.
  2. On the Tools panel of the Toolbar Customization dialog, select an option from the list of Views
    • Your selection will determine not only what buttons are available in the Toolbar Buttons list, but also what view types your custom toolbar will be present in.
  3. Still on the Tools panel, browse the list of Available Toolbar Buttons and click on a toolbar button that you would like to add to your custom toolbar.
    • A description of the tool's use displays under the available buttons list.
    • If the selected button is a Parent Tool you will see a small triangle  displayed to the left of the name which can be used to expand the list of associated Child tools.
    • In X5 and prior programs you'll see the Views list on the left, Main toolbar buttons in the center, and Child tools will display on the right.
  4. Click on a button in the list, hold down your left mouse button and drag the selected button outside the Toolbar Customization dialog box.
  5. If you drag the toolbar button to an existing toolbar, the button will be added to that toolbar when you release your mouse button.
  6. If you drag the toolbar button into the drawing area, a new toolbar will be created and the button will be placed in that toolbar.
    • This toolbar can be dragged and docked to the top, bottom or side of the Chief Architect drawing area, or it can remain floating.
    • Similarly, you can dock or undock existing toolbars to customize their locations as you wish at any time.
  7. Continue adding toolbar buttons to your new toolbar as desired.
  8. To rename the toolbar, select the Toolbar panel of the Toolbar Customization dialog.
    • Select the toolbar from the list and then click once on the name to rename the toolbar.
      In X5 and Prior, Click on your toolbar's name in the
      Toolbars list and click the Rename button.
  9. Also on the Toolbar panel, you can choose which views you wish to see this toolbar by simply placing a check mark in the appropriate columns.
    In X5 and older programs, your custom toolbar will now display any time you are in a view of the type that you selected in step 2.
