Creating a Custom Sail Shade
Reference Number: KB-00842
Chief Architect Premier
I would like to create a custom shaped shade sail in Chief Architect. Is this possible and if so, how would I go about doing it?
A custom sail shade can be created by utilizing Chief Architect's terrain tools.
To create the shape
  1. First, launch Chief Architect and select File> New Plan .
  2. Next, we need to draw the overall shape of the shade sail in plan view, which can be done by using a CAD polyline.
    Select CAD> Boxes> Rectangular Polyline  and click and drag out your rectangular polyline in plan view.
  3. To reshape the Rectangular Polyline, use the Select Objects  tool to select it, then use its edit handles, along with the Break Line  and Change Line/Arc  edit tools to create the correct shape for your Shade Sail.
  4. Once you are satisfied with the shape, use the Select Objects  tool to select the CAD polyline, and use the Convert Polyline  edit toolbar button to display the Convert Polyline dialog.
  5. Move the radio button to Terrain Perimeter and click OK to display the Terrain Specification dialog.
    Note: If the Terrain Perimeter option is greyed out, then the template that you started this new plan from must have already had an existing Terrain Perimeter in it. Locate and remove this terrain perimeter to continue.
To add elevation points at each corner of the sail at the height you will attach it.
  1. Select Terrain> Elevation Data> Elevation Point  and click to place an elevation point, setting the appropriate value for each corner.
    For the purposes of our rectangular example, we set the upper right and lower left elevation points to 10' and the bottom right and upper left elevation points to 5'.
  2. Now that the elevation points are set, use the Select Objects  tool to select the terrain perimeter and click the Copy and Paste in Place  edit button.
  3. With the copy now selected, click on the Convert to Plain Polyline  edit tool to convert it to a plain polyline.
  4. Next, with the plain polyline still selected, click the Convert Polyline  edit toolbar button again to display the Convert Polyline dialog. This time, select the Terrain Feature option and click OK.
  5. The Terrain Feature Specification dialog will display. Select the Line Style panel, use the drop down menu to change the Layer to CAD, Default, and click OK.
  6. Select 3D> Create Perspective View> Perspective Full Overview  to create a 3D view.
  7. Select Tools> Layer Settings> Display Options  to display the Layer Display Options dialog for the Camera View Set.
  8. Remove the check mark from Disp column for the "Terrain Perimeter" layer and click OK.
  9. You should now see the shape of your shade sail.
To create a symbol out of this object
  1. While still in the 3D view, select Tools> Symbol> Convert to Symbol  from the menu.
  2. In the Convert to Symbol dialog, use the drop-down menu to select the symbol category of Fixture (Exterior), click the Add To Library and Show Advanced Options check boxes, and click OK.
  3. The Symbol Specification dialog will display.
    On the 3D panel, specify the Symbol Name, such as Rectangular Shade Sail.
    In Chief Architect X2, check Double-Sided under Faces.
  4. Next, on the Options panel, set the Height Off Floor to the value of the lowest point you set in the terrain.
  5.  Click OK to complete these changes and add the shade sail to the Library Browser.  You can then place this shade sail symbol from the Library Browser into future plans, as well as change its size, specify materials, etc.
