Using the Extrude Object Edit Tool
Reference Number: KB-00931
Last Modified: October 23, 2023
How do I use the Extrude Object edit tool to turn a Face object into a 3D solid?
Basalt monolith in garden with white fencing
The Extrude Object edit tool can be useful for creating a solid object instantly from a 2-dimensional face object. Faces are two-sided, can display in 3D views, and can be used to create custom solid objects.
For the purposes of this example, we will start by drawing a face in the 2D floor plan view, however, faces can also be drawn in Cross Section/Elevation views. We will then extrude the face to create a basalt column.
To create the face
  1. Select Build> Primitive> Face , move your mouse in to the drawing area, then click, drag and release the mouse button to draw the first edge.
  2. Click to define the endpoints of additional edges, then click at the original starting point to finish drawing.
    Note: A Face must have at least three edges.
    If you are having trouble clicking at the original starting point, you may have disabled Endpoint snapping. To toggle it back on, select Edit> Snap Settings> Endpoint. A small checkmark will display on the icon when this feature is enabled.
    Face drawn in a plan view
  3. Once drawn, Faces can be then be extruded to create solid objects.
To extrude the face
  1. Using the Select Objects  tool, select the newly created face.
  2. Click on the Extrude Object  edit tool.
  3. In the Extrude Object dialog:
    • Set the X Delta.
      In this example, this value was set to 6", which will offset the extruded surface 6" to the right, relative to your plan view.
    • Set the Y Delta.
      In this example, this value was set to 4", which will offset the extruded surface 4" up, relative to your plan view.
    • Set the Z Delta.
      In this example, this value was set to 36". This determines the vertical distance of the extrusion, setting the height of the shape in this example.
    • Click OK.
  4. Select the newly created shape and click on the Open Object  edit tool to display the Shape Specification dialog, where you can access the Materials panel and choose an appropriate material, then click OK to apply the change.
    For the purposes of this example, we browsed to the Manufacturer Catalogs> Formica> Formica Brand Laminate> Honed Finish> 3690 Basalt Slate.
    Materials panel of the 3D Solid Specification dialog
If you have created another type of primitive, such as a Box or Pyramid, you can also choose the Explode Shape edit tool in order to convert its sides into individual faces, which can then be extruded to create a wide variety of different types of objects.
Often you can use these tools in combination with the Solid Union, Intersection, and Subtraction edit tools to create almost any type of custom shape desired. These shapes can then be converted into 3D symbols, such as fixtures or furnishings, for use in future plans. To learn more, see the Related Articles section below.
