When I place an object in a plan, a Question message will sometimes ask "Do you want to turn on the display of this layer in the current view?"
What does this mean?
This Question message will display if you try to draw, place, or have the program generate an object that will be placed on a layer that is not turned on in the current view.
For example, if you are in floor plan view and the "Windows" layer has been set not to display, and you try to place a window in a wall, this message will appear.
