Using Bump Maps to Make Realistic Water Effects
Reference Number: KB-01807
When I ray trace my image the water in my plan looks like glass. How can I make it look like water with different ripple effects?
The traditional way of creating water using a texture image can create some great looking images, however, in Chief Architect, there is even more power available in using bump maps.
On the right side of this image we have created our pool and applied a generic water material from the Core Catalog. The resulting ray trace reveals a glass-like surface on the water, so the reflection on the surface is unchanged.
On the left side of the image the same water material is used, but a bump map has been applied. Notice the ripples in the surface and the distorted reflection.
Bump maps are simply images that are layered under the face, created by the original material, and the program uses the dark and light areas in the bump map to simulate changes in the surface of the model.
In this example, we will illustrate how applying a bump map can greatly increase the quality and realism of the swimming pool.
To set up the scene
  1. From a standard Full Camera ,  select the Adjust Material Definition  tool and click on the surface of the water.
  2. In the Define Material dialog's General panel select the color for the material, in this case a light blue.
  3. On the Texture panel make sure to clear any reference to a texture file.
  4. On the Properties panel verify that the Material Class is Transparent is set to Water(1.33).
  5. Check Use Bump Map in Ray Trace Views and then click Browse to find our bump map.
    *The bump map used in this article can be found in the Attachments section of this article.
  6. As this is a pool, and the water feature is large, we will set our Ratio to 100" by 100" with a Height Multiplier of 0.01.
    As the bump map is increased in size the height multiplier is reduced to keep the waves from being too tall.
    If you want a more agitated looking pool, then simply increase the height multiplier or decrease the Ratio.
    Trying different combinations will give you a feel for how the material of your choice interacts with the bump map.
  7. Click OK to accept the changes to the material and you are ready to begin your Ray Trace .
The result should apply a wavy pattern to the surface of the water distorting the objects beneath the surface.
Helpful Tips:
  • Since a bump map is just an image, you can use any image you have, or can find, to simulate a pattern.
    Keep in mind that the ratio and height multiplier can be changed accordingly if you don't have a texture.
    If you are using a texture, then the ratio of the bump map will match that of the texture.
  • For many materials, it is important to match the size of the bump map with the size of the texture being used on the material.
    In this situation, you may want to use the texture image as the bump map as well, which you can do in the Define Material dialog by copying contents of the Texture File field on the Texture panel, and pasting it into the Use Bump Map in Ray Trace Views field of the Properties panel.
