Creating a Solid Fence
Reference Number: KB-01993
Is there a way to create a solid fence for my design?
Creating a solid fence can be accomplished using the standard Fencing tools. In this article we will outline how to do this in Chief Architect.
To create the fence
  1.  Click Build> Fencing> Straight Fencing , the click and drag to draw a straight fence segment, and repeat to connect several segments together, much like drawing walls in Chief Architect.
  2. Using the Select Objects  tool, hold down the Shift key on your keyboard and click to select each of the fencing segments.  Click Open Object
  3. On the Rail Style panel of the Fencing Specification dialog, set the rail type to Panel, and select Step Terrain or Follow Terrain.
  4. Under the Newels/Balusters panel, specify the height of your fence and change the Newel Width to 0".
  5. Change the Panel Type to Solid.
  6. Under the Materials panel, change all of the materials to your desired fencing material, such as the Stacked Stone material.
  7. Take a Perspective Full Camera view to see the results.
