Manually Installing Core Catalogs for Chief Architect Lite
Reference Number: KB-02901
Last Modified: September 28, 2015
I am unable to download the Core Catalog files for Chief Architect X6 Lite, how can I manually install them?
Follow the steps below to download the catalog files to your computer, then copy them to their respective locations.
It is recommended to create a folder on your computer, in an easy to access location such as your desktop, where you can save these files to.  If you do not choose to do so, then they will download to whatever default location your web browser is set to, typically your Downloads folder.
To download the Core Catalog files
  1. One by one, right-click the following links and choose Save Link As (or appropriate counterpart for your internet browser), allowing you to save the file to a specific location.
  2. Direct it to save to the new folder you created.
  3. Download and save the Core Libraries files:
  • Download and save the Referenced Files files:
    • CoreCatalogFiles
    • CorePlantFiles
    • Referenced Files are compressed .zip folders and need to copied as-is; do not open or extract the contents of these files.
    Open both the folder containing the downloaded files, as well as the destination location where the catalog files will be copied to, then copy or move the files from the download folder to the core catalog folder.
    To install the core catalog files on Windows
    1. Close Chief Architect Lite X6.
    2. On your keyboard, hold the Windows key and press R once to open a Run dialog.
    3. In the Open line of the Run dialog, type %programdata% and press OK.
    4. Locate and browse into the Chief Architect Lite X6 folder.
    5. Copy the downloaded Core Libraries (.calib) files into the Core Libraries folder.
    6. Copy the downloaded Referenced Files (.zip) files into the Referenced Files folder.
    To install the core catalog files on a Mac
    2. Open Finder and in the menu select Go> Go To Folder.
    3. In the dialog type /Library/Application Support and press Go.
    4. Browse into the Chief Architect Lite X6 folder.
