Using Fonts Found in an AutoCAD File
Reference Number: KB-00682
Last Modified: September 16, 2015
I have a number of fonts that I have used with AutoCAD in the past, and would like to know how to make use of these fonts with Chief Architect. These fonts have a number of different names and a file extension of .shx. Can I use any of these .shx fonts in Chief Architect?
AutoCAD can use two different kinds of fonts: Windows TTF (TrueType) fonts and Native AutoCAD SHX (compiled Shape) fonts
Chief Architect can make use of .TTF (TrueType) fonts, as well as .FON (Non-True Type) fonts. However, before Chief Architect can use them, they must be installed in the Fonts folder within your operating system.
  • Fonts on a Windows computer are located in your Fonts folder which can be accessed through the Control Panel.
    For information on locating your Fonts folder and installing fonts can be found here:
  • The Mac operating system has 2 ways to manage fonts: using Font Book or by managing the fonts manually.
    More information on managing the fonts on your Mac can be found here:
Unfortunately, it is not possible to use .shx fonts in Chief Architect, as these fonts are used exclusively by AutoCAD.
