Message: The cabinet already has a fixture or appliance inserted into it
Reference Number: KB-00969
DESCRIPTION
I would like to add multiple appliances to a cabinet, but when I try to do this a question message asks,
"The cabinet already has a fixture or appliance inserted into it. Would you like to replace it?"
Why is this happening?
RESOLUTION
In Chief Architect Premier, Chief Architect Interiors, and Home Designer Pro, you can insert multiple appliances into the front of a cabinet using the Cabinet Specification Dialog as outlined in the article linked below.
Inserting Multiple Appliances into a Single Cabinet
Home Designer Architectural, Suite, Essentials, and Interiors will require you to place the appliances into separate cabinets and then either place those cabinets side by side, as for an offset vanity, or to stack those cabinets, such as for a stacked microwave, wall oven and warming drawer. To learn more, see the related articles section below.
