When I open a project, plan, layout, or a library file, the version of the Chief Architect software program that launches is not the version that I want to use.
How can I change this file association so that when I open files, they open in my preferred program version?
If you have just installed a new version of Chief Architect or Home Designer, you may receive this message upon launching the software for the first time:
Select Yes to associate project, plan, layout, and library files with this version of the program, or select No if you want these files to be associated with the program version you last chose.
If you're not receiving this prompt and files aren't opening correctly in the program version you would like to use, please follow the steps listed in this article.
Project, plan, layout, and library files will now be associated with this program version.
