I want to be able to apply a solid color to a surface displaying a pattern, or texture, and blend the two. How do I do that?
    Instead of using the Material Painter to replace a material with a new one, we can use it with the Blend Colors With Materials tool to blend a color with a textured material.
 view looking at the material that you'd like to blend with a color.
 view looking at the material that you'd like to blend with a color. .
            For more information on the various modes, please access the "Using the Different Material Painter Modes" resource in the Related Articles section below.
 edit tool. The paint roller
 edit tool. The paint roller  icon will follow your cursor when this setting is enabled.
 icon will follow your cursor when this setting is enabled. from the menu.
 from the menu. icon instead.
 icon instead. or Object Mode
 or Object Mode  is active, you can continue to click on surfaces to apply the selected material. When you are finished, press the Spacebar on the keyboard.
