Is there a way to use my bluetooth laser measuring device with my Chief Architect desktop application so I can take measurements of an existing job site?
A number of laser measuring devices have bluetooth capabilities, which allow you to interface with a computer that supports bluetooth connectivity.
Though other devices may connect and work with Chief Architect desktop software, only the Leica DISTO X1 has been tested and verified for compatibility.
Note: If you have a supported Apple device, instead consider using a bluetooth laser measuring device in unison with Chief Archiect's Mobile As-Built application to capture measurements of an existing space. Please see our ChiefBlog article on the topic to learn more. Bear in mind that As-Built files can only be imported into Chief Architect Premier; Home Designer does not support this feature.
Note: If you have trouble pairing your bluetooth laser measuring device to your computer, please refer to your device's documentation.
Note: If you notice that the unit of measurement (", ') is not following the measurement value, enter this in using your keyboard and then select the Enter/Return key.
If you'd like to use a different Leica laser measuring device model that supports bluetooth, consider installing and configuring DISTO™ Transfer, a program designed to accept input from your Leica device for use on your Windows-based computer. This software is not compatible for the macOS platform. For additional information on how to use the mentioned software with your Leica device, please refer to your device's documentation or Leica's Support.
