Apple Devices Compatible with Chief Architect As-Built
Reference Number: KB-03250
Last Modified: July 2, 2026
I am using an Apple device, but I'm unsure if it meets the requirements for use with the As-Built mobile application. What Apple devices are compatible?
The Chief Architect As-Built mobile application requires a LiDAR-compatible iPhone or iPad device running iOS/iPadOS 18 or newer. Recommended and supported devices are listed below.
Android devices are not supported with Chief Architect As-Built.
Chief Architect Premier X18 or newer is required to transfer/import As-Built models.
Recommended Devices
Note: iPad devices are recommended over iPhone devices due to the larger screen size.
  • iPad Pro 13-inch (M5, 2025)
  • iPad Pro 11-inch (M5, 2025)
Other Supported Devices
  • iPad Pro 13-inch (M4, 2024)
  • iPad Pro 11-inch (M4, 2024)
  • iPad Pro 12.9-inch (4th, 5th, and 6th Generations)
  • iPad Pro 11-inch (2nd, 3rd, and 4th Generations)
  • iPhone 17 Pro & 17 Pro Max
  • iPhone 16 Pro & 16 Pro Max
  • iPhone 15 Pro & 15 Pro Max
  • iPhone 14 Pro & 14 Pro Max
  • iPhone 13 Pro & 13 Pro Max
  • iPhone 12 Pro & 12 Pro Max
