Can I use a bluetooth laser measuring device with the Chief Architect As-Built application?
If you're using a supported Apple device, you can use a bluetooth laser measuring device, like the Leica DISTO X1, in unison with the As-Built application to capture measurements of an existing space.
Note: While other bluetooth laser measuring devices may connect and function with As-Built, only the Leica DISTO X1 has been tested and verified for compatibility.
Do not pair your Apple device with the bluetooth laser measuring device at this time.
Note: If the device fails to connect, tap on the device name once again. If you're still unable to connect your bluetooth laser measuring device to As-Built, restart your Apple device, disable and re-enable the bluetooth functionality within your device settings, then repeat Steps 2 - 4.
Note: Some bluetooth laser measuring devices will not prompt the keyboard to appear. Instead, only an input line will appear. Continue with the steps below.
