Enabling Terrain Tools When They are Grayed Out
Reference Number: KB-00714
Last Modified: July 28, 2026
Whenever I open a new drawing and go to the Terrain menu or try and select any of the Terrain tools on the toolbar, they are grayed out and inaccessible.
Why is this?
Before you can use the various Terrain tools, you must first create a terrain perimeter, and the floor the terrain perimeter was created on must be the active floor. The terrain perimeter provides Chief Architect with an area for terrain objects to be placed within.
The terrain perimeter is a closed polyline defining the boundary of the terrain that generates in 3D views and displays contour lines that are generated in plan view.
To enable the Terrain tools
  1. On Floor 1, navigate to Terrain> Create Terrain Perimeter  from the menu to create a basic rectangular terrain perimeter, then select Window> Fill Window  to see the terrain perimeter's extents.
    If the Create Terrain Perimeter option is grayed out, a terrain perimeter already exists, as plans are restricted to a single terrain perimeter. Use the following tips to try and locate the existing terrain perimeter:
    • Enable the display of the "Terrain Perimeter" layer by navigating to Tools> Layer Settings> Display Options  or by accessing the Active Layer Display Options  side window.
      If you believe the terrain perimeter may be located on a different layer, navigate to Terrain> Terrain Specification , access the Line Style panel to see the exact layer the terrain perimeter is on, then enable the display of this particular layer.
      To learn more about layers, please see the Related Articles section below.
      Layer Display Options dialog with the Terrain Perimeter layer displayed
    • Navigate between the different floor levels (e.g. Floor 0, Floor 1, Floor 2, etc.) while in a plan view and Zoom Out   to try and locate the perimeter. By default, the perimeter is a 50' x 100' rectangle and looks like the following image.
      Default perimeter in a plan view
    • If you still aren't able to locate the terrain perimeter and would like to instead delete the undiscoverable perimeter, as well as all of the terrain objects to start anew, navigate to Edit> Delete Objects , change the Delete Scope to All Floors, place a check in the Terrain Objects checkbox, then click the Delete button. Only proceed with this option if you're sure you want to delete the terrain perimeter and all existing terrain objects from the design.
  2. Once you have created or located the terrain perimeter, ensure that the floor level the terrain perimeter exists on is the active floor, then use the Terrain tool(s) of your choice to add terrain objects to the design.
