Message: The library catalog that contains the referenced button information could not be located, or is out of date. Please reconfigure or delete the button.
Reference Number: KB-01143
Last Modified: July 19, 2021
I am trying to place an object using a toolbar button, but keep encountering this error message:
"The library catalog that contains the referenced button information could not be located, or is out of date. Please reconfigure or delete the button."
How do I reconfigure the button?
This warning message will appear when the toolbar button that you have selected needs to be associated with an object from your Library.
To correct the error
  1. Click OK in the warning dialog to close it, and the Library Object Button Specification dialog will display.
    Library Object Specification Dialog
  2. Click on the Library button to display the Select Library Object dialog.
  3. Navigate to an appropriate replacement item, select it to highlight it, and click on the OK button.
  4. Select an appropriate button icon, or choose one on your computer, then click OK.
  5. Now, every time you select that Library Object toolbar button, it will place the new object that you have chosen from the Library Browser.
