I have searched through the Millwork items that include columns in the Library Browser and have determined that none of the options will suit my needs. How can I create a completely custom column?
Custom columns can easily be made by creating a molding profile and extruding the profile along a closed shape. Use the CAD tools to create a custom molding profile that is the actual height of the column you wish to create and half the width minus 1/2" (the molding will be extruded around a 1" square or circle). See the "Creating and Editing Molding Profiles" article in the Related Articles section for more information on creating a custom molding profile and adding it to your library.
For this example, the following molding profile shape is used:
Using a CAD circle instead of a square will result in a round column.
Tapered columns can also be made by using a custom molding profile such as the following:
