I have moved my Library Browser, Project Browser, Active Layer Display Options, and/or Tool Palette onto a secondary monitor which is no longer there or otherwise cannot locate it when I go to activate this side window. How can I reset it to its default position?
Resetting the side windows in Chief Architect can be done by accessing the program's Preferences.
If you have customized the layout of a single side window, such as the Library Browser, this can also be reset without resetting all of the side windows.
if you're on a Mac.
if you're on a Mac.
