Creating Project Files from Existing Plans and Layouts
Reference Number: KB-03206
Last Modified: August 13, 2025
I'm using the new Project Management feature and would like to import existing plan and layout files to create new projects. How do I create a project with these files?
When using Project Management in Chief Architect Premier X17 or Home Designer 2026, you can import plan and layout files into a new or existing project. Once they've been imported into a project, they are now managed by Chief Architect/Home Designer.
If the file you'd like to import is already linked to an existing layout, you should always import the layout file instead of the plan file. Importing the layout file will automatically import the linked plan file(s) along with it, meaning you will not experience any new missing links or additional copies of your plan(s).
If you import a plan file first and then choose to import the layout file later, the layout file will bring over the original linked plan(s) along with it, resulting in extra copies.
In this article, we will discuss the following:
Creating a project from an existing plan/layout
  1. Navigate to File> Open Plan/Layout .
  2. Towards the bottom of the Open Plan/Layout dialog that displays, underneath of the Unmanaged Files section, click Browse to search for the plan/layout file on your system.
  3. Once you've located the plan/layout file you'd like to import, click on it to select it, then click Open.
  4. The import process will begin, and you will be met with the Import To Project dialog, where you must choose between 3 options:
    In the Import To Project dialog, choose one of the 3 options.
    When importing a layout:
    • Import to a new Project will import the layout file and any associated plan files into a new project.
    • Import to existing Project* will import the layout file and any associated plan files into an existing project.
      *Applies to Chief Architect Premier.
    • Open layout but do not import to Project will open the layout file, but it will not be included in a project. Once you close out of the file it will no longer be listed within your Project Browser.
    When importing a plan:
    • Import to a new Project will import the plan file but not bring over any associated layout files.
    • Import to existing Project will import the plan file but not bring over any associated layout files.
    • Open plan but do not import to Project will open the plan file, but it will not be included in a project. Once you close out of the file it will no longer be listed within your Project Browser.
    When choosing to import into a project, Chief Architect will automatically search for other plan/layout files within the same folder as the initially selected file. If Chief Architect finds other plan/layout files, you will be met with the Additional Import Selection dialog, which will allow you to choose other plan/layout files to import into your new project, even if they aren't linked to the selected file.
  5. Once successfully imported, you will receive a message in the lower right corner indicating that the import was successful. You can now find your imported file(s) listed in the Project Browser .
    You will recieve a message after the project import is successful.
Creating a new project from a legacy folder
If you had previously organized your plan/layout files when using Traditional File Management, you may find it helpful to instead import an entire folder that contains your various plans/layouts.
  1. Navigate to File> New Project From Legacy Folder   or click on the Import Legacy Folder  tool within the Project Browser .
    This tool will allow you to select a folder and import any plans, layouts, and assets (such as materials or PDFs) into Project Management. It will also search through any subfolders inside of the folder you selected, and then create the same folder structure for your new project.
  2. In the Select Folder dialog that displays next, locate and select the folder you'd like to import, then click Select Folder to start the import process.
  3. Once successfully imported you will receive a message in the lower right corner indicating that the import was successful. You can now find your imported file(s) listed in the Project Browser .
Relinking plan and layout files
If you chose to import a plan and then import a layout into your project later, you may end up with extra copies of your plan file, and you may need to relink the correct plan to your layout.
  1. Open a layout file that is already imported into a project, then navigate to Tools> Layout> Referenced Plans/Layouts .
  2. In the Referenced Plans/Layouts dialog that displays, underneath of the Files Present area, you will see the plan files that are currently linked to your layout file. Select the plan file you'd like to replace, then click Replace Reference.
  3. The Replace Reference Plan dialog will then open, which will allow you to select a different plan from within the same project as your layout, or a file from your Common Documents.
    If you do not see the plan file you'd like to relink to, it's because it's not currently within the same project as your layout. You can either copy it from an existing project, or import it directly into your project.
    For more information on both of these methods, please see the Related Articles section.
  4. Select the plan you'd like to replace the original plan with, then choose Select. Once you're done relinking your files, click OK.
Return To Top
