I have created multiple lines and arcs that are all connected to one another, but a single CAD object is not being generated. Instead, the individual lines and arcs can only be selected separately. What am I doing wrong?
Individual CAD lines and arcs can be snapped together end-to-end to form a polyline, but only when Endpoint Object Snaps are turned on and Connect CAD Segments is enabled.
            Connect CAD Segments can also be toggled on and off on the CAD panel of the Preferences dialog.
    After a polyline has been created, a single edge can be disconnected using the Disconnect Selected Edge edit tool.
    The selected segment can now be deleted, moved or altered separate from the rest of the polyline.
        Alternatively, select CAD> Lines> Disconnect Edges to toggle the Disconnect Edges option. With this option turned on, each segment selected will disconnect from the polyline.
