I am using X16, Home Designer 2025, or a prior version, or Traditional File Management in X17, Home Designer 2026, or a newer version. How can I backup all of my user content associated with the software?
Backing up data means creating a copy of your files and saving them in a safe location so that they can be retrieved in the event of a problem. It's important to routinely back up your important data - including Chief Architect/Home Designer files and user content - because in the event of a hard drive crash or other computer malfunction, it's possible you might lose your work, or access to it, unless you have copies saved somewhere else.
Additionally, it's helpful to have this same content backed up so that it can be transferred to another computer.
Note: If you're using Project Management in X17, Home Designer 2026, or newer, please see the "Backing Up and Restoring Chief Architect Content Using Project Management" resource in the Related Articles section instead.
For information about restoring backed up user content in X16, Home Designer 2025, or prior, or if you're using Traditional File Management in X17, Home Designer 2026, or newer, please see the "Restoring Chief Architect Content Using Traditional File Management" resource in the Related Articles section below.
It is best to use a strategy that utilizes a backup location somewhere other than your local computer. Options include:
There are a number of different Chief Architect/Home Designer files that you may want to back up. You can back up some or all of them, depending on your needs:
Regardless of where you choose to save your backed up files, it is helpful to know how to copy and paste files in your operating system's file system. There are several ways, and all are easy.
When copying files associated with Chief Architect or Home Designer, it is important to begin by saving your work and closing out of the software.
Plan and layout files often reference a variety of other files such as images and PDFs. When backing up plans and layouts, it is important that these referenced files be included. A great way to do this is to use the Backup Entire Plan/Layout tool in X16, Home Designer 2025, and prior, or the Export Plan/Layout as Project tool in X17, Home Designer 2026, and newer. This will ensure that all referenced files, including those that have been imported, are backed up.
It's important to be aware that if either of the tools mentioned above are used in a layout file, the layout file, as well as all the plans associated with the layout will be backed up. However, when the tools are used while in a plan file, the layout file will not be included.
Note: If the "Send Backup Files to Zip Archive" box was not checked, you will need to create a new, empty file folder on the Desktop for the plan and referenced files to be backed up to:
By default, core, bonus, and manufacturer catalogs are saved in the ProgramData folder on Windows or the Application Support folder on macOS. These are hidden file locations and may require you to use the "Run" utility on Windows or the "Go to Folder" function in macOS to access.
Close out of Chief Architect/Home Designer prior to completing the following steps.
%programdata%
and then click OK to open the Program Data folder./Library/Application Support
then click Return.If you have moved your libraries to a custom location, then you will want to instead reference this location to backup these files. You can confirm the location of your "System Library Database Folder" on the Folders panel of the program's Preferences dialog.
Do NOT copy or backup the Program_Data folder or the dont_change.dat file. They contain unique, encrypted registration information and if you try to use a copied and pasted version of either, your license registration will no longer be recognized by our registration server.
The user catalog stores custom items that you may have added to the Chief Architect/Home Designer Library Browser. To back up this content, use the Export Library function.
Note: This export process may take some time, depending on the size of the library. If you have an extensive User Catalog and it's taking a considerable amount of time to export, it may be necessary to consolidate the catalog or separate it into smaller folders to export.
User content, such as user-created templates, archives, toolbars, hotkeys, and other user-specific data is saved in the Chief Architect/Home Designer Data folder. The Chief Architect/Home Designer Data folder is located in your Documents directory by default, and its name will begin with the full name and version of your Chief Architect/Home Designer program followed by the word Data - for example, "Chief Architect Premier X17 Data" or "Home Designer Pro 2026 Data".
The default file path for this folder on Windows may be one of the following, but may also vary depending on your product and version:
C:\Users\ [ YOUR USERNAME ] \Documents\Chief Architect Premier X17 Data
C:\Users\ [ YOUR USERNAME ] \Documents\Home Designer 2026 Data
And on macOS:
/Users/ [ YOUR USERNAME ] /Documents/Chief Architect Premier X17 Data
/Users/ [ YOUR USERNAME ] /Documents/Home Designer 2026 Data
If you have moved your Chief Architect/Home Designer Data folder to a custom file location, refer to the location you have moved it to instead. You can confirm the location of your Data folder in the Preferences dialog. On the Folders panel, take note of the file path next to the "My Data Folder" or "Data Folder for Current User" heading.
You can backup the entire Chief Architect/Home Designer Data folder if you wish, or only the subfolders and files that are of importance to you. Each of these are described in further detail below:
If the Chief Architect Premier Data folder is renamed, moved or deleted, the program will automatically replace it using default information from the program's installation folder. When this occurs, customized user settings and custom user library content will not be available.
Do NOT backup, copy, or modify any of this content while Chief Architect is running.
