Which Mac models are compatible with Chief Architect X18 and Home Designer 2027 products?
A listing of all supported Apple Mac models that are compatible with the current version of Chief Architect products can be found below. Each model that is listed begins with the Model Name and is followed by its Model Identifier.
If you are thinking about purchasing a new computer for the purposes of using Chief Architect or Home Designer, please see our ChiefBlog article to learn more about computer specifications.
Note: To identify the model of an existing Mac, please access the "Locating Your Computer Specifications" resource in the Related Articles section below. Alternatively, you can access the following Apple resource: Find your Mac model name and serial number.
16 GB of RAM (unified memory) is a minimum requirement for the current version of Chief Architect products. Please compare your computer specifications with the applicable system requirements resource in the Related Articles section below.
Also, please access our Known Incompatibilities page to view a list of software and hardware incompatibilities.
Mac Studio
iMac & iMac Pro
MacBook Pro
Mac mini
MacBook Air
Mac Pro
