Placing a Gate in a Fence or Terrain Wall
Reference Number: KB-00874
Last Modified: April 2, 2026
I have placed a fence or terrain wall in my design. What is the best way to add a gate?
Gate is placed within a terrain wall
Once a fence is created, a gate, which is a door symbol, can seamlessly be placed into a fence, much like doors can be placed into walls. This is because fences are classified as railings, which are a type of wall object.
Terrain walls however, are classified as terrain paths, and it's not possible to place gates directly into these types of objects. The solution is to replace part of the terrain wall with a section of fencing, thus allowing for the placement of a gate.
To create a fence
  1. Select Build> Fencing> Straight Fencing , then click and drag in plan view to create one long section of fence.
  2. Using the Select Objects  tool, click on the newly created fence, then click the Open object  edit button.
  3. In the Fencing Specification dialog that displays:
    Newels/Balusters panel of the Fencing Specification dialog
    • On the Newels/Balusters panel, specify your desired Height, as well as the other properties located here.
    • Access the Rail Style panel to make additional modifications to how the fence is built.
    • Specify the desired fence materials by accessing the Materials panel.
    • Once all of your desired changes have been made, click OK.
To create a terrain wall
  1. Select Terrain> Terrain Wall and Curb> Straight Terrain Wall , then click and drag in plan view to create one long section of wall.
    If you're unable to place a terrain wall, it's possible that a Terrain Perimeter hasn't been created or you're on a floor level that your Terrain Perimeter isn't placed on. Navigate to Terrain> Create Terrain Perimeter or move to the correct floor level (Floor 0 or Floor 1).
  2. Select the newly placed terrain wall, then use the Add Break Break tool icon edit tool located in the Edit toolbar to create three separate terrain wall sections.
    Note: To learn more about this edit tool, please view Video # 303: Using the Break Tool.
  3. Select the middle terrain wall section, click the Disconnect Selected Edge Disconnect Selected Edge tool icon edit tool located on the Edit toolbar, then Delete  it.
    Floor plan view with a deleted terrain wall segment
  4. Using the Select Objects tool, click on one of the terrain walls, hold down the Shift key, then click the other terrain wall to add it to the selection set.
  5. With the two terrain walls selected, click the Open Object edit button.
  6. In the Terrain Path Specification dialog that displays:
    General panel of the Terrain Path Specification dialog
    • On the General panel, adjust the Width and Terrain to Top values to your liking.
    • On the Materials panel, select the "Terrain Path" component, then specify your desired material.
  7. Select Build> Fencing> Straight Fencing , then click and drag to draw a fence segment between the two terrain wall segments.
  8. Click on the fence segment to select it, then click the Open Object edit button to open the Fencing Specification dialog:
    • On the General panel, set the Thickness to your liking.
    • On the Rail Style panel, select Open under the Specify Railing section, then choose if you would like Newels/Posts to appear by enabling/disabling this checkbox.
    • On the Newels/Balusters panel, specify your desired Height, as well as the other properties located here if Newels/Posts are enabled.
    • On the Materials panel, select the "Newel" component, then specify your desired material.
  9. With the fence still selected, center it between the two terrain walls using the Center Objects  edit tool.
To place a gate in a fence or terrain wall
  1. Select Build> Door> Hinged Door and click on the fence to place an opening in it.
    Alternatively, there are a variety of gate styles located in the Library Browser by navigating to Chief Architect Core Catalogs> Architectural> Fences and Railings> Gates. There are also a variety of gates located in bonus and manufacturer catalogs.
    To learn more about obtaining additional libraries, please see the "Obtaining and Updating Library Content" resource in the Related Articles section below.
  2. Click on the newly placed door or gate to select it, then click the Open Object edit button.
  3. In the Door Specification dialog that displays:
    General panel of the Door Specification dialog
    • On the General panel, you can change the Door Style using the Library button, adjust the Width, Height, Thickness, and Floor to Top/Bottom values, and more.
    • You can adjust whether a single or double door is created, as well as a variety of other options on the Options panel.
    • Access any additional panels, such as the Arch, Hardware, and Materials panels to make further adjustments.
To place cap or other decorative finishing on top of posts, you can utilize the various caps, finials, and shapes located in the Chief Architect Core Catalogs.
