The display of temporary dimensions on my screen is too small when I am zoomed out. How can I make their display bigger so that they are easier to read without affecting the size they will be when printed?
The minimum display size of temporary dimensions and object labels can both be specified on the Appearance panel of the Preferences dialog.
 if you are on a Mac.
            This is the on-screen size and does not affect printed or exported output. To use the printed scale, set these values to 0 or turn on Print Preview.
            Printed dimension and label sizes are set by modifying the text styles used by those dimensions or labels.
Note: This will not edit the size of the text within your plan/layout file. For information on adjusting the size of text placed in your designs, please see the Related Articles section below.
