I'm encountering one of the following messages when saving or closing one of my files:
Why is this occurring?
One of these message might display when the program tries to generate an Archive of the file you're currently working with in the background, or when creating a backup, but is unable to complete the process.
There are a number of reasons why this occurs:
Archives are located in C:\Users\[YOUR USERNAME]\Documents\Chief Architect Premier X17 Data\Archives\ on a Windows machine or /Users/[YOUR USERNAME]/Documents/Chief Architect Premier X17 Data/Archives/ on a macOS machine by default. If you have redirected your program's Data folder, (which contains the Archives) from the default location to a network or cloud storage service location, or to an external storage device, you may receive the first error mentioned at the beginning of this article. It's recommended to keep the program's Data folder on a local, and always accessible, drive.
If you suspect that your Documents directory is being stored on OneDrive or iCloud and you're experiencing errors or unexpected behavior, please access the appropriate resource below:
Check to make sure that you have a reasonable amount of free/available drive space. If you don't have at least 5 GB of available space, please access the appropriate resource below to learn how to free up space on your system:
Windows allows a maximum file path name length of 260 characters, while macOS allows a maximum file path name length of 255 characters.
When Chief Architect creates Archives of plan and layout files, these files' path names may be longer than those of the original files, and may be the cause of this message.
For example, the full path name of an Archive file for a plan titled Smith.plan might be C:\Users\[YOUR USERNAME]\Documents\Chief Architect Premier X17 Data\Archives\Smith_b8f17c2e88a82622dc3c96618e1a4976e0d2f795Smith_2024_11_28.plan or /Users/[YOUR USERNAME]/Documents/Chief Architect Premier X17 Data/Archives/Smith_b8f17c2e88a82622dc3c96618e1a4976e0d2f795Smith_2024_11_28.plan which has 140+ characters.
When choosing a file naming convention, try to use short file names and limit the use of folders nested within other folders.
There are several reasons why file, or data corruption may occur on a disk. The most common cause is actively working on files in an unsupported fashion; such as over a network or cloud storage service, or off of an external storage device.
Other things that could cause a file to become corrupted include:
It's possible that you may be able to access data that has been corrupted; however, even if you are able to, it's likely that the file(s) will have missing information and may become further corrupted in the future. You should no longer try to use the affected file(s) and instead resume work on a backup copy. Please see the Related Articles section below to learn more.
File corruption can sometimes be resolved, depending on the severity of the damage. The Check Disk Utility on Windows and the Disk Utility on macOS are used to scan and fix disk errors, which may prevent future corruption. For more information on these utilities, please visit the Microsoft or Apple website.
If you continue to experience this error, please contact our Technical Support team directly, and include all of the following files listed below.
Note: Some of the requested information may identify you, as well as specific information about your computer, but it will also help us determine the source of the problem. Please be assured that any files submitted to Chief Architect Technical Support will be used for troubleshooting purposes only.
